Home Forums Sign Making Discussions File Swapping Anyone got 5 mins???
  • Anyone got 5 mins???
    Posted by Phil Barnfield on 22 May 2007 at 15:36
    Need this logo vectorising if possible.
    Had a bash, but I just cant seem to get it right using Corel. Maybe I am best to invest in SignLab or something which is better at doing the job!!
    AI or EPS appreciated.
    Thanks guys
    Shane Drew replied 18 years, 6 months ago 8 Members · 12 Replies
  • 12 Replies
    22 May 2007 at 15:39
    Phil, Corel 3x is suppose to be pretty good at vectorising from what I have read on the boards so buying Signlab or Flexi probably won’t help much at all, you just need a bit more practice I would imagine.
  • Glen Mathers
    22 May 2007 at 15:47
    Done a quickie for ya Phil, might need a little tidy up.
  • Phil Barnfield
    22 May 2007 at 16:17
    eh. Not had this problem before….
    Import into Corel Draw (v12) and it doesnt seem to be vectored, just bitmapped. Any thoughts anyone, or am I being a bit slow today 🙄
  • Lorraine Clinch
    22 May 2007 at 16:35
    Hi Phil, converted to ai for you, might help?
    22 May 2007 at 16:50
    i’d use corel 12, can’t see anything there that would not be done in corel, but could in signlab, what tools were you using ? should be a fairly quick job,
    Hugh
  • Brian Hays
    22 May 2007 at 17:55
    Better off not using the vectorising tools whatever program you have Phil. IMO you are better off building up the image manually. Attached my go anyway…..
  • Brian Hays
    22 May 2007 at 17:58
    quote Phil Barnfield:
    Usually best using the PS, PRN, EPS filter when importing EPS files into Corel.
  • Brian Hays
    22 May 2007 at 17:59
    …CDR file in case you still have problems with the other formats…
  • Phil Barnfield
    23 May 2007 at 07:10
    Not sure what went wrong tbh. I had redrawn it as I would normally, but then when I export it to PLT (HPGL) file for my cutter it came out all wrong. Not sure why…. it usually works ok.
    One thing to say:
    "I LOVE YOU GUYS, THANKS"
    :thanks2:
  • Phil Barnfield
    23 May 2007 at 07:13
    quote Hugh Potter:
    Hugh
    Bezier tool and shapes that I then coverted to curves and chopped bits out. It seems that when I did the chopping using that Virtual Segment Delete tool, it has taken away some of the bits that I can still see in corel but not when I export as PLT. Strange.
  • Chris Windebank
    10 June 2007 at 11:13
    Brian, where is the EPS filter, am I missing something, searched the help index but cannot find?
    10 June 2007 at 11:27
    quote Chris Windebank:
    Chris, when you import something, when it comes to the file list, look in the pull down menu for ‘file types’ and the bottom of the screen, and you’ll see the option there.
