Home Forums Sign Making Discussions Vinyl anyone ever used tack rags when applying vinyl graphics ?
  • anyone ever used tack rags when applying vinyl graphics ?
    Posted by Michael Taylor on 18 December 2006 at 19:40
    Hello again
    Just wanted to no if anyone has ever used tack rags when applying vinyl graphics to Vehicles.
    Mick
    Martin Pearson replied 18 years, 11 months ago 5 Members · 6 Replies
  • Brian Little
    18 December 2006 at 19:58
    well normally used before spraying …hmm long time since i seen them being used… providing the adhesive doesnt leave any trace which im sure it wouldnt …why not
  • Michael Taylor
    18 December 2006 at 20:02
    quote brian little:
    Do you think it would be a good for wiping after cleaning just before applying do you think?
  • Nick Minall
    18 December 2006 at 20:03
    have a look here old posts
  • Michael Taylor
    18 December 2006 at 20:13
    quote Nick Minall:
    Thanks for that someone said something about it the other day. I will get some tomorrow thanks again
    and any idea whats the best cleaning fluid is as i use meths but can find its stinks the whole work shop out.lol
    Thanks again nick
  • Darryl Seager
    19 December 2006 at 10:32
    I use a tack rag,just let it ‘float’ across the surface, they are after all covered in a wax!!
    i also use one with my Edge2…. unfold it, then wrap around a piece of
    10mm foamex(doubled to make 20mm) and let it sit against the brush as the vinyl travels through. Surprising how much it picks up. Turn it inside out as required therebyusing both surfaces .
    Darryl
    19 December 2006 at 12:53
    Using tack rags isn’t going to help you with the problem you are having as they will only remove dust and dirt, they won’t stop you getting air bubbles which are probably caused by the way you apply the vinyl.
    As for cleaning fluids apart from meths you could try lighter fluid which probably works out a bit expensive or isopropyl alchohol (IPA).
    Make sure your squegee is flat and not bowed in the middle, sharpen it to make it flat again if it is bowed as this will help prevent air bubbles.
