Anybody Tried Flood Coating Static Cling?
I quite often use cut vinyl lettering on Static Cling for shop windows. I find it gives much stronger colours than printing and is something I can do quickly in house without sending off for prints.
However I need to give some block colour to a window sign and wonder if anybody has tried flood coating static cling.
I have tried a small 500mm sample which seemed to work OK and stuck to the window fine.
In the past people have mentioned the cling ruckling after a while due to the cut vinyl and Cling vinyl stretching different amounts when using letters but I have actually had good results so far without this happening when using Metamark M& and Metamark Cling.Also thinking if the whole sheet of static cling is flooded then there wouldn’t be two different thicknesses so whole lot should shrink & stretch together.
I am doing this for two reasons i) the shop windows already have expensive window film on which could be damaged if vinyl laid on top (rather the film would be scratched if vinyl was removed) and ii) an outside application is innappropriate.
Anyone tried it?
