Home Forums Printing Discussions General Printing Topics Any Roll-to-roll printer without heat!
  • Any Roll-to-roll printer without heat!
    Posted by Erdy Cem on 29 May 2020 at 11:42
    Hi guys,
    Do you know any roll-to roll printer which doesn’t give heat at all? The media we would like to print on is a multi layer label-kind of media, outer layer is kraft and inner layer is PE. I’m looking for a digital printer which doesn’t heat enough in order not to wrinkle/melt PE.
    Stefan Byrne replied 5 years, 7 months ago 4 Members · 5 Replies
    29 May 2020 at 11:48
    I think an LED UV cure Printer would do this if I am understanding you correctly.
    You could try calling Printmax to better advise you on this as they supply our group members.
    https://www.printmax.co.uk
    https://www.rolanddg.co.uk/products/pri … er-cutters
    29 May 2020 at 12:01
    What size?
    If your pockets are deep enough check our the Zeikon digital presses
  • Erdy Cem
    29 May 2020 at 13:42
    quote David Hammond:
    What size?
    Sizes are narrow… between 120 and 300mm. Xeikon must be too dear..
  • Erdy Cem
    29 May 2020 at 13:43
    quote Robert Lambie:
    Thanks Robbie.. Will check with them..
  • Stefan Byrne
    29 May 2020 at 15:09
    Have a look at the Mimaki ucjv
    No heat required
    Option for white ink
    Print and cut
    Stef
