Home Forums Sign Making Discussions General Sign Topics Anti-Static wipes
  • Anti-Static wipes
    Posted by Richard Urquhart on 6 October 2004 at 14:03
    hi all thought i would let you know about a new product from u-pol its a panel wipe cloth that we use before painting a car panel to remove silicone etc etc i have been using them to prep foam board as not only do they clean there also good and reducing static build up
    you just pull wipe out of tub and clean surface its so easy
    part number up 0301 around £7 per tub
    called panel prep fast
    single action no dry wiping
    anti static
    and no i don’t have any thing to do with u-pol
    rich
    Nicola McIntosh replied 21 years, 2 months ago 6 Members · 13 Replies
  • 13 Replies
  • Cookster
    7 October 2004 at 09:09
    Sounds good Rich
    Where can we get these cloths from, we have a local paint & panel firm in our area will they stock them?
  • Richard Urquhart
    7 October 2004 at 10:28
    yes mate, there only just out so may not have stock
  • John Singh
    7 October 2004 at 12:23
    I’ve been after these for some time
    I think they used to be called tac rag or something
    The car spray shop I went to didn’t stock it
    Strange 😕
    Be handy to know a local supplier
    7 October 2004 at 12:39
    Are these a wet-wipe?
    I assume so if you pull them out of a tub.
    Just curious, as I haven’t seen them around here.
    Altho you guys had deodorant wipes first!
    Took us about 2 years to get them in.
    I usually just use a fabric softener dryer sheet,
    but these anti-static things sound intriguing.
  • John Singh
    7 October 2004 at 12:55
    No Jill these are not cosmetic 🙄
    The ones I’ve used you pull out of a box
    They have a slight moist feel to them but they do a marvelous job in removing stuff from say a car (that’s an automobile) panel in prep for spraying
  • Richard Urquhart
    7 October 2004 at 12:57
    sure are there like baby wipes but contain solvent cleaner ,we like them cause there easy and no need to wipe dry they come in fast and slow we use the fast one cause it drys in seconds
  • Richard Urquhart
    7 October 2004 at 13:01
    john tac cloths are not the same there as there called tacky and don’t do any thing other than remove dust from panel after its been panel wiped
    if say we panel wipe a bumper it makes it so static and all the dust is attracted to it even after tac clothing its a nightmare but with these wipes its much much better
  • John Singh
    7 October 2004 at 20:38
    Righty!
    ( 😳 Sorry Jill you were on the right track)
    Ok! So where do we source these then Rich?
    (As they sound so much better than tac cloths)
    7 October 2004 at 20:54
    Yup, John, I wasn’t gonna wipe my ***** or my face with one! 😉
    That would burn!
    I can’t wait till we get them here.
    What a smart idea.
  • Richard Urquhart
    8 October 2004 at 08:40
    hi all any automotive paint supplier
  • cabriofx
    8 October 2004 at 14:50
    Hi guys
    If you cant get the wipes, the same solvent is available in solution 5 ltr tub and is actually called panel wipe. I ve been using it for the last 8 yrs, and it does definitley help wipe away and sticky residue of banners, static of foamex etc, and help prep surfaces clean before applying any graphics onto vehicles especially.
    It leaves no stickyness and evaporates easily. The only thing is, as with all solutions, has chemical warnings. Can be purchased from any automotive supplier
    IT DOES EXACTLY WHAT IT SAYS ON THE TIN.. 😛
  • Richard Urquhart
    8 October 2004 at 18:54
    your 100% right about panel wipe but as stated in my post panel wipe makes plastic and foam-board quite static once its been cleaned
    these wipe eliminate static build up which is more why i like them
    8 October 2004 at 18:56
    quote cabriofx:
    just started using it the other day!! really good stuff!! 😛 😛
    Nik
