Home Forums Sign Making Discussions General Sign Topics Anti-static spray & app. fluid
  • Anti-static spray & app. fluid
    Posted by Richard McCombe on 29 November 2006 at 10:17
    For donkeys we have dry applied or simply used soapy water. However I had experience at using a product called OVERLAY which was quite amazing. Where would I get this?
    Also I am looking for an anti-static spray, where would I get this?
    thanks,
    Richard
    Shane Drew replied 19 years, 1 month ago 4 Members · 5 Replies
  • Gwaredd Steele
    29 November 2006 at 10:56
    You can get Overlay from Cherwell Sign supplies. It’s overated & overpriced IMO, & I get just as good results from using Chewells own brand stuff (Prospray) mixed with 50% water.
    I’m pretty sure they sell anti-static too, but I’ve never got on with the stuff myself.
    Get them on 01280 840297 – really decent bunch. I’ve used them for years.
    29 November 2006 at 11:01
    i think allot of this stuff is a gimmik. have a clean working area with a decent worktop. (not a plywood type worktop) clean it down, wipe panel and surrounding area with a damp cloth etc
    lots of things come into play that will cause crap under your vinyl. i.e. you could have the cleanest work area around, but bits of dust on the front of your top from an earlier job. remove the vinyl from the backing paper and the dust will jump onto the vinyl due to static charge. as i said, "everything must be clean"
    how clean just goes with the working conditions of the individual… it takes me only a minute or two to clean around where i would lay up a sign.
    you can buy "Overlay" from europoint.
    29 November 2006 at 11:14
    If you want to reduce static, just atomise water around your work environment. Usually something that simple can reduce static substantially.
  • Richard McCombe
    29 November 2006 at 11:17
    Thanks for the promp replies. How do I atomise water? Chemistry no my strong point at school!
    R
    29 November 2006 at 11:31
    quote Matic Media:
    R
    just use a spray bottle with a fine mist.
