Home Forums Sign Making Discussions General Sign Topics … and another query
  • … and another query
    Posted by Marcella Ross on 26 October 2007 at 11:49
    I have 50 small signs to produce for a car sales forecourt, the type of sign you see on the window of the cars stating the mileage/mot/spec etc.
    Anyway customer wants them dry wipe so they can be reused. Now the last lot he had were all done on fluted display which obviously isn’t dry wipe. I previously bought some clear vinyl material before that was used on signs to make them dry wipe (it wasn’t just a laminate) but I can’t remember for the life of me what it was called or where I got it from!
    Is there a dry wipe type of board already out there that I can buy, obviously there must be for making drywipe boards, but does anyone know of a supplier? Or is fluted and a clear overlay a cheaper option?
    Marcella Ross replied 18 years, 2 months ago 6 Members · 7 Replies
  • 7 Replies
  • Tim Painter
    26 October 2007 at 12:02
    Whiteboards are constructed with one of three material: the cheaper melamine resin, polyester coated steel and more expensive models made from porcelain…
    Apparently….
    I would of thought the way you are doing it is the cheapest way. MacTac do a clear vinyl Marcie.
    Tim.
  • Fred McLean
    26 October 2007 at 12:27
    Try Sahara Presentations,they do hand held and slightly larger melamine type boards.
    Mightn be cheaper/easier buying them in rather than covering something with a dry-wipe film 😕
    26 October 2007 at 12:39
    thanks Fred. I was thinking more from a hassle point of view. If I could get away without covering in a film then thats quicker for me.
    I’ll give them a bell, thanks. 😀
  • Jon Marshall
    26 October 2007 at 14:55
    Hexis do a dry wipe film.
  • Russell Spencer
    26 October 2007 at 15:36
    any polyester anti-graffiti film should work as a dry wipe, we use the one from Europoint for that very reason
    Robert Horne do a dry wipe sheet buts its only 0.8mm thick, requires bonding to something and is very brittle. But its cheap.
  • David Glen
    26 October 2007 at 15:49
    Marcella, I generally just flood coat panels with dry erase vinyl to make white boards.
    Works perfectly.
    http://www.metamark.co.uk/pages_sv/whiteboarMd.htm
    26 October 2007 at 16:42
    cheers, David, just gave my Metamark rep a call.
