Home Forums Software Discussions General Software Topics An interesting one for the Acrobat gurus
  • An interesting one for the Acrobat gurus
    Posted by Rod Gray on 21 February 2006 at 12:03
    Hi Guys,
    i came across this pdf file http://www.bbcmagazines.com/teachme/ttm_web_activity3.pdf which is freely available for download.
    On closer inspection, i noticed that the long, scenic image at the very bottom retains it`s sharpness no matter how close you zoom in. It seems to be some sort of layer which you can`t access.
    Other images on the page loose their sharpness as you zoom in.
    Does anyone know how the this long scenic image can be extracted with the view to printing it on my Cadet and using it as a sort of border for my daughter`s bedroom?.
    I`ve tried copying and pasting using acrboat 6.0 `s “select image” option and cropping but it still loses it`s resolution.
    Cheers,
    Rod
    Rod Gray replied 19 years, 10 months ago 4 Members · 8 Replies
  • 8 Replies
    21 February 2006 at 12:17
    Rod, Acrobat Pro has capabilities of manipulation of non-protected PDF’s.
  • Rod Gray
    21 February 2006 at 12:46
    Thanks dave,
    Pro would allow me to select that specific layer or collection of vectors?.
    Rod
    21 February 2006 at 12:48
    hi rod u can save them as an eps file from pro, if i can remember rightly 😀
  • Rod Gray
    21 February 2006 at 12:50
    Thanks Nik,
    i`ll go hunt down a copy of Pro.
    Thanks again.
    Rod
    21 February 2006 at 13:02
    ok.. rod.. i emailed u a few hours ago
  • Tim Shaw
    21 February 2006 at 13:38
    the border you want is in Illustrator format, save the PDF and open it in Illustrator ( 8 prob best) and then you can do what you want with it.
  • Rod Gray
    21 February 2006 at 13:39
    Simply perfect dave.
    I`ll need to find a way of incorporating “Dave Rowland” into my daughter`s bedtime Balamory story 🙂
    Perhaps you should open up a sign shop next to “Pocket and Sweet” on the main St 🙂
    Thanks again mate. 😉
    Rod
  • Rod Gray
    21 February 2006 at 13:41
    Cheers Tim,
    Son`t have illustrator 8 but dave managed to extract it for me using Acrobat Pro and it has worked out perfectly.
    Even Archie`s kilt is vectorised ! 🙂
    Thanks.
    Rod
