Home Forums Sign Making Discussions General Sign Topics aluminium swing panel supplier ?
  • aluminium swing panel supplier ?
    Posted by Derek Heron on 16 October 2006 at 11:13
    can you buy new panels for these if so where
    the one i have to replace is 500x 700 with two slots at the top approx 300 mm apart i have the old panel but it has been screenprinted
    tried covering in white vinyl but it shows through
    derek
    Derek Heron replied 19 years, 2 months ago 6 Members · 7 Replies
  • 7 Replies
  • David Rogers
    16 October 2006 at 11:18
    Try coating it in black first…it covers a multitude of sins.
  • Derek Heron
    16 October 2006 at 11:32
    thanks dave tried it but you can see the raised print
    derek
  • Martin Cole
    16 October 2006 at 11:46
    Bought a few of these in the past from A-Display 023 9222 1222
    Just looked at size 825 x 520, tad bigger than you need may not make any difference. Can’t remember them being very expensive either.
    Martin
  • Neil Churchman
    16 October 2006 at 13:05
    Derek,
    have you considered removing the ink with screenwash or ink thinner?
    a lot of those panels are stove enamelled so there’s a good chance you
    can clean the ink off, although you should check a small area first.
  • Lee Attewell
    17 October 2006 at 09:31
    Wet and dry the edges of the text, and use a grey backed blockout vinyl to cover???
    Would that help?
  • Nick Harper
    30 October 2006 at 15:52
    It sounds like a Eurasign Panel, which are available from Spandex – 0800 772633.
    I know the panels are 700 x 500. Not sure about the gap between the holes though. I think it’s only about 220mm on them.
    But you can get spare panels.
    Might be worth a try.
    Nick
  • Derek Heron
    30 October 2006 at 18:37
    hi decided to cut a new bit from alupanel offcut
    customer over the moon kept the old one to stick on the wall will ring spandex thanks for the pointers
    Derek
