Home › Forums › Sign Making Discussions › General Sign Topics › Alternative to lugging bags of concrete about / waterless.
Posted by David Rogers on 3 July 2012 at 08:43Warren Beard replied 11 years, 11 months ago 10 Members · 10 Replies -
I bet they are pleased the link has been posted.
Had the email through a few times now..looks good.
I’ll have to make my big 10 gallon water containers redundant at this rate 🙁
Looks great indeed. But what with the weight issue? Concrete has a certain counter weight which mostly is necessary for your sign construction. Couldn’t that be a problem with Kongcrete?
quote Bart Van Wassenhove:Looks great indeed. But what with the weight issue? Concrete has a certain counter weight which mostly is necessary for your sign construction. Couldn’t that be a problem with Kongcrete?
My thoughts entirely
it would seem as if you would simply be gluing the post to the ground!Simon
quote Simon Worrall:quote Bart Van Wassenhove:Looks great indeed. But what with the weight issue? Concrete has a certain counter weight which mostly is necessary for your sign construction. Couldn’t that be a problem with Kongcrete?
Yea, me too. I guess it might be OK in hardcore or very dense earth, but I think they need a fair old weight of concrete to lower the centre of gravity to keep it stable – especially in wind.
i spoke with them just over a month ago…
they have had these two videos on isigntube.com from around then too which is why they contacted me.which reminds me i need to return his call from a few days ago! 😕 😳
<embed width=”452″ height=”361″ quality=”high” bgcolor=”#000000″ wmode=”transparent” name=”main” id=”main” allowfullscreen=”false” src=”http://www.isigntube.com/player/vPlayer.swf?f=http://www.isigntube.com/player/vConfig_embed.php?vkey=1715466cd580a448cf82″ type=”application/x-shockwave-flash”>
<embed width=”452″ height=”361″ quality=”high” bgcolor=”#000000″ wmode=”transparent” name=”main” id=”main” allowfullscreen=”false” src=”http://www.isigntube.com/player/vPlayer.swf?f=http://www.isigntube.com/player/vConfig_embed.php?vkey=f5b8c02c0e46513b98f9″ type=”application/x-shockwave-flash”>
quote Martin Cole:I bet they are pleased the link has been posted.
LOL, Martin, youre lucky. Only 10 Gal water containers….We use 44 Gal drums 😮 They are to heavy to load on the truck, so we load them empty and fill them on the vehicle. With a 4 Gal bucket filled in the kitchen, through the workshop, into parking area, into drum…..
I’ve been meaning to buy a hosepipe for 3 years, but always only remember about it when the guys are busy loading up to install in a waterless area.
Did make a "note to self" again. Will forget about it by the 2nd cup of coffee…. 😀
I’m about to try it out on a couple of small signs, i will post my results.
quote Bart Van Wassenhove:Looks great indeed. But what with the weight issue? Concrete has a certain counter weight which mostly is necessary for your sign construction. Couldn’t that be a problem with Kongcrete?it uses compressive force to hold posts in place or so i’m told
Did anyone ever try this stuff, if so how did you find it?
thanks
I tried it, battled with it in the cold as it didn’t expand enough and ended up using twice the amount so ended up a lot more expensive than post mix, haven’t tried in Summer as yet but don’t think I would convert just yet and stock both types and will stick with postmix for now.
It does work though.
