Home Forums Sign Making Discussions General Sign Topics Alternative to cleaning dust off signs?
  • Gary Birch
    2 March 2014 at 21:33
    We use tack rags but we also clean regularly too
  • Matthew Chittenden
    2 March 2014 at 21:36
    Sounds good, can you recommend a supplier at all?
    2 March 2014 at 21:54
    we coat once with water and then use a window-scraper to dry/clean the surface (like what a window cleaner uses)
    we then soak again to apply the graphic
    2 March 2014 at 21:58
    We do that for flood coating large single colour vinyls, we just have an issue with cut graphics (contour cut logos etc) with application tape. Im gonna try the tack cloths, i’ve also purchased some anti static spray from maplins, hopefully this will reduce the problem.
  • Gary Birch
    3 March 2014 at 06:15
    quote Matthew Chittenden:
    http://dmfwakefieldltd.co.uk/ is where we get ours but only as they are local to us
    Gary
  • Chris Windebank
    3 March 2014 at 09:11
    any good motor factors will sell tack rags, make up the order and get some 3m masking tape at the same time. They do excellent prices if brought by the box
  • Chris Windebank
    3 March 2014 at 09:12
    oh and most motor factors will do free delivery same day
  • Dave Harrison
    3 March 2014 at 09:37
    I wipe down the surface with this when mounting to acrylic or foamex.. for ACM i find a tac rag is enough.
    http://www.wurth.co.uk/technical-chemicals/cleaning-and-care-materials/plastic-cleaning-and-care/upvc-cleaner-anti-static-1000ml
