Alignment problem with test cut
Hi Guys,
Seem to have a problem with the test cut and all cuts tbh…
I have the Bridge Pro 870 32" cutter (same as refine)
Its test cut is a square with a diamond inside it.
It cuts ok but the top left corner of the box is always slightly rounded.
I just cant seem to get a sharp nice cut.
When cutting text it adds this curve to the bottom of the text and looks poor.
Im cutting at 90G force and about 100mm/s
Im a complete newbie to cutting and only got the cutter last night so i may be doing something silly.
the curve gets bigger when i add force and not so obvious when i lower it but when it starts to look ok the vinyl hasnt been cut deep enough to weed 🙁
Any help would be great!
What settings do you use for normal vinyl?
Ad.
