Home Forums Software Discussions Corel Software Ai file to Corel 12
  • Ai file to Corel 12
    Posted by Paul Seamer on 18 June 2010 at 13:08
    Hi Guys,
    Not sure if this is in the right place. Please move if needed.
    I am trying to open an Adobe Illistrator file in Corel 12 and it’s coming through broken up. What’s the best file to export it as from Illy to Corel 12?
    Paul
    Alan Drury replied 15 years, 6 months ago 3 Members · 4 Replies
    18 June 2010 at 13:12
    How do you mean – broken up? V12 is a fairly old version now but it did a fairly good job on vector AI files if not saved at too higher version.
    Alan D
  • Paul Seamer
    18 June 2010 at 13:18
    Hi Alan,
    I no it’s pretty old 😳 . The template is coming through fine but where it should be is one piece it is broken up with a few gaps so you can’t fill with a colour or put outlines etc round it. Hope this makes sense.
    Paul
    18 June 2010 at 13:19
    Do you mean that it has vertical lines cutting through it?
    That happens to me sometimes in both GA and Corel 12.
    Or do you think that it might be some sort of gradient fill in the file?
    Or could the file not be saved in an earlier version?
    18 June 2010 at 13:58
    The vertical lines were an issue when exporting from Corel with ‘simulate complex fills’ clicked on, deselct that and problem was sorted – does Illustrator have a similar option?
    Alan D
