Home Forums Printing Discussions Roland Printers Advice – RS-640 Head Cap has movement
  • Advice – RS-640 Head Cap has movement
    Posted by David Hammond on 26 October 2011 at 15:47
    Just carried out my routine clean on the printer.
    Cleaning around the head caps (think that’s the term), noticed that the far left cap has a little play in it.
    The other 3 are all solid in place.
    Not sure if it will cause any problems, I assume it will continue to seal correctly?
    David Hammond replied 14 years, 1 month ago 2 Members · 2 Replies
    26 October 2011 at 16:14
    the outer case should be firm but the centre capping part is spring loaded presuming the RS is similar to other rolands.
    26 October 2011 at 19:44
    From memory and not knowing much about the machine.
    It appears that the outer case is fixed onto a spring loaded carriage, and the inner black caps clip onto the outer case.
    I will post a pic tomorrow to clarify.
    Just seems odd that 1 is loose the others aren’t.
