advice please applying vinyl to VW Transporter?
HI folks,
I’m a new uksignboards.com member from Ireland – great site, lots of useful info the sign maker.I started making signs and car number plates about 2 years. Most of my sign work up to now is basic sign writing on cars/vans and exhibition signs.
However, I’ve just taken on a job to do 2 VW Transporter vans for a local company. The vans are white, and they want (on both sides) grey vinyl starting at a point on the very top rear sweeping down across the side of the van. Something to the affect of the VW Caddy van in this picture:- http://www.inform.as/nytt_05.html ,in this case where you see the white vinyl, in will do this in grey vinyl. Some of the sign writing will be applied on top of the grey in 1-2 colors.
Here’s my problem(s):
The sides on the VW transporter are not very flat, as you can see from this photo: http://www.janhoejsauto.dk/images/VW%20 … 20side.jpg Here are my concerns:# Can you advise how would I should go about applying the grey vinyl so that I can get the vinyl to fit perfectly to the contours of the side panels.
I have never done this before.# Do I apply the vinyl wet or dry. Should I use a heat gun.
# Will a need a 2nd person to hold the vinyl in place while I squeegee the vinyl into place.
# Do I require any special tools.
# What type of vinyl should I use for this job.
Thanking you in advance.
Declan
