Home Forums Sign Making Discussions Vinyl advice please applying vinyl to a painted surface
  • advice please applying vinyl to a painted surface
    Posted by Warren Beard on 14 June 2007 at 22:13
    Hi All
    I have a shop sign to do and is silver vinyl 751C on to an already painted surface (a few months old)
    What should I be aware of, if anything…… besides the clean well preparation.
    Would a felt squeegee be the better option as paint is not always perfectly smooth?
    Warren
    Dave Harrison replied 18 years, 5 months ago 5 Members · 5 Replies
  • David Rogers
    14 June 2007 at 22:19
    Couple of things spring to mind:
    Get rid of the oily grime with meths, ALWAYS apply dry – no worries about what kind of squeegee (felt is good once the tape is off). Don’t worry about a few lumps & bumps – you can always fix it when the tape is peeled. And if it’s not a hot day – heat bond the vinyl to the paint (heat gun) and it’ll ‘suck right in’ to the texture of the paint and get a good bond.
    Done right – it should last longer than the paint!!
    14 June 2007 at 22:22
    just as Dave said…
  • Warren Beard
    14 June 2007 at 22:23
    Cool, thanks guys.
    sounds simple enough.
    Warren
  • Andy Gorman
    14 June 2007 at 22:29
    I did one like that a few months ago. The decorators had left a slightly bumpy texture, so I did as Dave suggested: go over it all with a felt squeegee after removing the tape. End result looked great even though the vinyl showed the texture underneath. Make sure they’ve done a good job of the painting or you could pull paint off when you remove your tape.
  • Dave Harrison
    14 June 2007 at 22:55
    quote :
    heh. . I did that once 😳 it’s not a nice feeling when you remove the app tape and half the fascia comes away with it. After learning the hard way I ‘ll apply dry. . go have a cuppa. . ( leave for 20mins ) come back and spray the app tape with a light mist of application fluid. this tends to release the application paper and it’ll falls away without subjecting the surface underneath with any force ! Then go over with a heat gun and felt squeegee. .
