Home Forums Vinyl Cutter Discussions General Cutter topics Advice on which plotter software is best?
  • Advice on which plotter software is best?
    Posted by Colin Aburrow on 1 February 2011 at 21:30
    Hi All,
    I could do with some advice on what plotter software is best for cutting vinyl.
    I have recently bought a SummaCut D140 and was supplied with a copy of Winplot, which I am finding lacking, especially on multicolour designs.
    I have used a version of SignLab 7 before and found it a lot easier to master, but it is an old version I picked up a few years ago, and I think it is a cracked version and I have been having problems loading, and when sending to plot, it keeps crashing.
    I would really appreciate some input on what software you guys use, and the advantages and disadvantages. I have noticed that a lot of people on here seem to use Signlab and Coral Draw. Is there a reason for this?
    At the moment, I am using Creative Suite CS3 and Quark.
    Colin
    Brian Hays replied 14 years, 11 months ago 8 Members · 17 Replies
  • 17 Replies
    1 February 2011 at 21:37
    Colin
    for cut vinyl, Signlab is, in my opinion, the best and easiest to use, it has all the tools to make cutting easier.
    If you buy just the cut vinyl version its not that expensive.
    You can do all the design you need, and with proper shadows, welding and cutting layers etc, from one package, and signlab supports most, if not all plotters.
  • Colin Aburrow
    1 February 2011 at 22:25
    Hi Peter,
    Would you go for the Signlab 9 X Grade or Signlab 9 Vinyl Pro X not sure what the difference is. (apart from a few hundred pounds!!)
    And thank you again for all the advice you have given me so far, guess I owe you a drink at some point.
    Colin
    2 February 2011 at 09:03
    I’m with Peter on this for vinyl I use Signlab V9 and have always used Signlab for cutting.
    I am probably known here as a Corel guy and for text intensive stuff (menus)and print setup (litho) I still think Corel has the edge but for cutting the job will always go into SL. I do use Winplot and Cutting Master but SL is head and shoulders easier, more flexible and generally better. SL also has tools such as shadow and bleed on the weld that does set it above Corel, this may or may not change in the future.
    I cannot comment on Flexi or the others as I’ve not used them at any length, my ideal signmaking software package is Signlab AND Corel Draw, with those two you are covered.
    Alan D
  • Brian Hays
    2 February 2011 at 09:24
    Colin, you can see a comparison chart here.
    https://www.cadlink.com
    Gradient fills & plug-ins, etc, are the main difference between Vinyl & Vinyl Pro. Mostly stuff that is useful for designing for output to a large-format printer.
  • Colin Aburrow
    2 February 2011 at 09:46
    Thanks Alan I think signlab is going to be the choice for me to.
    Thanks Brian not sure if the chart helped or has confused me more. Does this mean I can use designs produced in signlab vinyl or vinyl pro to either just cut vinyl and also use designs to print and and then contour cut as well.
    Colin
  • Alan Wharton
    4 February 2011 at 08:59
    i know signlab is proberly 1 of the most used software packages but i find Vinyl Master Pro so much easier and quicker to use, im proberly 1 of the minority that use VMP but it is good, you used to be able to download a demo which was fully working apart from you couldnt save your work etc i dont know if you can still d/load it from there site, and also its less than £200 retail and i have seen it as low as £99 with dongle so price wise its pennies compared to the likes of signlab/flexi etc.
  • Colin Aburrow
    4 February 2011 at 09:02
    Hi Alan thanks but I have just bought Signlab.
    Colin
  • David-Foster-
    4 February 2011 at 09:31
    Brian
    I was always of the belief that Signlab was expensive so never entertained it. I use Coreldraw and Signtools. When I see the new boys on here that have just bought a plotter and are using Signlab I always think they are using a pirate version as it costs well over a £1000
    How much is it for the entry version and the vinyl version please? Just the RRP, not particular deals or anything.
    4 February 2011 at 09:35
    David
    https://www.vehicleoutlines.co.uk
  • David-Foster-
    4 February 2011 at 09:41
    Doh! Thanks Peter 😳
  • Colin Aburrow
    4 February 2011 at 12:47
    quote :
    David I might be a new boy when it comes to sign making but have been producing exhibition displays & retail pos for many years now. The plotter & solvent machine is a new venture for us (diversifying 😀 ) I have always been interested in sign making and am really looking forward to trying to learn as much as possible. I bought an old plotter and a version of Signlab 7 a few years ago which I have now found out to be a cracked version which has given me all sorts of problems importing ect to the extent that I had no confidence in producing a good job quality job so have not pursued this area of our business. Having the correct software to give me the etc that I can now take on work without all the hassles I have had in the past. The cost for Signlab 9 basic vinyl cut cost £450 from Impact. (worth it just to have confidence & backup.
    Colin
    4 February 2011 at 16:28
    Signlab comes in many flavours and the base vinyl version coupled with Corel will just about see you covered. Not sure if the SL base version has the different weld functions, if it has at £450 ish its a bargain. If you use it everyday it will pay for itself many times over.
    Alan D
  • Peter Dee
    4 February 2011 at 18:10
    Colin, you won’t regret your purchase. I have been using Signlab since it came on 6 floppy disks!
    Vinyl package does have some worthwhile extra features; colour welds and 1100 fonts & Corel font support being a couple.
    I still think Power Weed is one of the best features in Signlab as it makes weeding tricky graphics & text a breeze.
  • Brian Hays
    4 February 2011 at 18:33
    quote David-Foster-:
    Brian
    David, the Vinyl version is £450+vat if you are eligible to buy it as a crossgrade, which is what Colin did.
    Older versions used to be quite basic, but since version 8, it has been far more comprehensive.
  • Colin Hibbitt
    4 February 2011 at 20:33
    Colin
    i too have been a signlab fan since it started – cant go wrong
    Brian whats the difference from 8 to 9 and how much??
    Colin – Plymouth
    4 February 2011 at 21:02
    quote Colin Hibbitt:Colin, i too have been a signlab fan since it started – can’t go wrong. Brian, what’s the difference from 8 to 9 and how much??
    Colin – Plymouth
    https://www.uksignboards.com
  • Brian Hays
    It’s £225 from Vinyl Pro 8.0, which I think you have!
    Try typing Signlab 9 into YouTube; quite a few videos show the new features on there.
