Home Forums Sign Making Discussions Vinyl Advice on the Best Choice of vinyl to use?
  • Advice on the Best Choice of vinyl to use?
    Posted by Gordon Forbes on 14 March 2004 at 22:18
    I have a year 200 transit to do and I am a bit worried about the deep receses on the side panels and I have to birdge these with the name. I dont have a choice really he has such a long name.
    What I would like to know is what would be the best vinyl in your opinion for doing this?
    I know how to do it and have done it on a training day using Oracal.
    I have at present Multi Fix 5000 series and would like to know if this is suitable or do I need a cast for it.
    Your help as always would be greatly appreciated.
    Goop
    Nicola McIntosh replied 21 years, 9 months ago 5 Members · 5 Replies
    14 March 2004 at 23:20
    I always fold the lettering into these receses. This way you don’t have to worry about shrinkage. If you apply the name to the van then cut between the letters where the name bridges the recess – you can then fold the letters without having to stretch the vinyl. Ok the gap between the letters does open up when done this way – but in the real world it is not noticable.
    Ordinary 751 or 651 series Oracle or similar is fine. I would only consider using a cast vinyl when having to deal with compound curves and the need to stretch the vinyl into the recesses – but even then I’ve managed this with oracal 751.
    14 March 2004 at 23:33
    Forbie,
    Man that stinks, huh.
    You should get the dude to change his name!
    Seriously, tho, when faced with this pickle I bend the edges of the vinyl as described above & heat with a hair dryer to set. I have even gone the extra mile and trimmed pieces of vinyl to stick behind the space where the gap is (like on a van door) to lessen the visual “break”. I usually just cut extra letters for where the cutting will occur and use them for patches.
    But I would ALWAYS use cast vinyl on a vehicle.
    Calendered vinyl, I have been told, is rolled out like a big pile of pie dough. It has a memory and tends to shrink back. Cast is better.
    Love…JILL 😉
  • Dave Bruce
    15 March 2004 at 09:33
    Hi Forbie,
    I have done a few transits with the name right across the side, and what I did was use the hinge method, that is tape the centre of the work to the van, top and bottom, cut the backing to one side of this(a little tricky), then work my way along applying the vinyl to the contures of the van, when one side of the hinge is done, just remove the hinge and apply the other side. Worked for me anyway, the only thing you need to watch is the line of text does go up/down (I just take a measurement as I am going along). Hope this makes sense.
    I was using Oracal 751
  • Deleted User
    Deleted User
    15 March 2004 at 09:53
    Morning Forbie,
    I did a transit with deep recesses this weekend and I, like you, decided to ask around as to whats the best material to use. The feedback I got was always to use KPMF cast on all recesses or altenatively the Hexis Suptac range is lot better than most calendered materials. In the end I used the KPMF cast on the recesses and on the back I used the Hexis. Customer was well chuffed!
    15 March 2004 at 22:13
    hi forbie
    i second what phil says, but i was given the multi-fix 5000 from a signmaker that had had enough of the trade, so got a few rolls! i don’t like it, found it a tad thick and a devil to weed!! stick to oracal 751 as davebruce quoted you can’t go wrong!!
    Nik
