Home Forums Sign Making Discussions Traditional Advice on infilling carved letters.
  • Advice on infilling carved letters.
    Posted by Harry Cleary on 8 November 2011 at 17:58
    I have been asked by somebody (they are at their wits-end trying to get a memorial sculptor to do it) to infill a carved marble plaque, high up on a wall. The plaque cannot come down unfortunately. The letters are fairly shallow, is the only way to do this just by carefully lettering them? Or is there another way?
    Thanks in advance.
    Harry Cleary replied 14 years, 1 month ago 2 Members · 2 Replies
    8 November 2011 at 18:11
    using your brush just quickly back fill the letter with a dabbing motion without allot of care for going over the edges of the letter. force the bristles into the corners of the serifs etc. then using a soft cloth wrapped around the edge of say a nylon squeegee. drag across the tops of the high ground of the letters. ive used the edge of cutup card board in the past. this will remove most of the excess paint. then using a soft rag around your finger and dampend with something like meths or thinner, just wipe away any residue on the high ground. because its marble it would mark or damage anything.
    do a small test on a single letter before you start, but ide imagine you will do it no sweat. depending on what you back fill with, will determine whats best to clean. i prefer meths because thinner often activates and makes the colouring run.
    also when cleaning, rubbing, make sure you rub in one direction. not sure if this matters with the likes of marble but on surfaces like brass as it has a faint grain you can see abrasion if you cross it. so one direction rubbing.
    been years ince ive done anything like this, sorry for being a bit vague. 😀
  • Harry Cleary
    10 November 2011 at 09:14
    Cheers Rob…will give that a go! 😀
