Advice on fixing hanging swing panel
Hi All
I recently did a job for an existing customer of mine and after quoting for a swing sign he opted to get his own bracket and panel made up (I still did his fascia sign)
This is the bracket which he has fitted himself;
http://www.metalhangingsigns.co.uk/larg … p-269.htmlhe had a wooden panel made up from 18mm ply and wooden framing and painted to match his fascia. The panel weighs 10kg and is 1m wide by 500mm deep.
Now he has asked me to fit the panel up for him as it has no fixings on it to hang up. I have these 2 fixings but am very unsure if the eye bolts will be strong enough, the "L" shaped brackets would have been perfect but due to the size of the panel the eye holes are not close enough to use.
http://www.jagsignsupplies.com/aqshop/c … .php?id=98
http://www.jagsignsupplies.com/aqshop/c … php?id=518I want to go give it back to him as I don’t want the risk of it coming down or am I just over precautios and these eye bolts will be OK?
or do I walk away? because it is hanging over the street.
Warren
