Advice on fitting a large banner – approx 25m x 3m
Morning guys, I have been asked to supply and fit a large banner to the side of a building.Ill be subbing out the production but it’s the fitting which I’m concerned about.
The banner will be going flat against the wall of a derelict building which is due to be demolished. It’s fairly exposed but it shouldnt catch the wind. The bottom edge of the banner will be roughly 15ft above the ground so we are looking at a 20-25ft maximum working height. I imagine a banner of this size is going to weigh a fair bit and fitting from ladders will be difficult/dangerous – can it be fitted safely from a cherry picker? There is an issue with access because there is a steel/concrete overhang projecting approx 1.5m out from the wall about 3 ft below where the bottom of the banner will be. This means I can’t get a scissor lift directly underneath and close enough to the wall, or fix the bottom of the banner from ladders, although I could use it as a working platform (no safety rails!).
It’s my first experience of specifying and hanging a banner of this size so any advice would be welcome.
Thanks,
Owen
