Home Forums Sign Making Discussions Neon, LED, Lighting Advice on fitting 8m x 1.5m banner system
  • Advice on fitting 8m x 1.5m banner system
    Posted by John Dorling on 11 September 2009 at 14:52
    Hi All
    I wonder if anyone has any advice on fitting a spirit flex ‘F2’ section profile banner track system 8m x 1.5m?
    I have used the system before but on much smaller signs and wondered if there might be any tricks that would make installation easier, particularly when fixing the banner in place, as this has always seemed to me to be the tricky part.
    I plan to cut the track in my workshop and take to site ready to fit. I will drill and rivet to steel clad building. I will be working from a cherry picker as the job is too high for my scaffold and it will be much quicker and safer this way.
    Any advice much appreciated.
    Luke s Bremner replied 16 years, 3 months ago 1 Member · 1 Reply
  • 1 Reply
  • Luke s Bremner
    12 September 2009 at 22:23
    Hello
    I fitted 1x 8M x 4.8M, 1x 8M x 4.8M 2x 2m x 3m last sunday. You might want to use some butter fly fixings as well as rivets and make sure you use plenty of fixings, hit as many studs as you can.
    It should be prity easy fitting this as its only 1.5M wide.
    good luck
