Home Forums Printing Discussions General Printing Topics Advice on encad novajet630
  • Advice on encad novajet630
    Posted by dean104 on 12 April 2006 at 15:37
    Hi there
    Just bought encad630 can someone answer a few questions?
    1. It’s come with a box which says firey with lots or sockets on the back
    and sounds like it’s has a hard drive in it, can you explain what this does
    and if its worth keeping if so is there a manual available for it.
    2. The ink cartages that are in printer say GS yellow, GS magenta,
    GS cyan GS+ black is this ok i.e. the black has GS+ ink or should it be GS?
    Thanks Dean
    Checkers replied 19 years, 7 months ago 3 Members · 3 Replies
  • solvent
    12 April 2006 at 16:10
    the fiery is the rip for the printer.
    this is an old hardware type rip that you put on your network and upload files to.
    if you do not have a software rip then you need to keep this.
    gs+ should be fine.
  • dean104
    12 April 2006 at 17:16
    Hi there
    Thanks for reply solvent..
    Just loaded paper tried to do test print and this error came up
    Internal Error Shutdown Carriage Axis Failure.
    Any ideas
    Also
    Do I need a driver / software for my computer to run the firey box if so do you know where I can get this from & any instruction manual
    Thanks Dean
  • Checkers
    12 April 2006 at 18:25
    Hiya Dean,
    From my experience, a carriage access failure normally means that the carriage bushings are shot and need to be replaced. From what I recall, they aren’t expensive, but they can be a p.i.t.a. to replace.
    Here’s a link to the encad technical bulletin…
    http://www.encad.com/Support/KB/export/083.pdf
    Good luck,
    Checkers
