Home Forums Printing Discussions Roland Printers advice needed setting an ip address in versa works?
  • advice needed setting an ip address in versa works?
    Posted by Lynn Wang on 30 November 2012 at 17:06
    hi
    when installing a vesra works . how i can fill ip address?
    the ip address means internet ip? like 192.168.1.2
    after filling the ip, i need to change printer ip address ?
    wonder what this ip address do between pc and printer?
    dont understand how it actually works?
    and more and more questions !!!
    thanks
    David Hammond replied 13 years ago 1 Member · 1 Reply
  • 1 Reply
    30 November 2012 at 20:13
    What printer do you have?
    The IP address will be for the local network, not the internet. Everything from your router will have a unique IP.
    Most devices like pc’s, laptop, tablet don’t need a static (it doesn’t change) ip address, whilst servers, network printers, and most shared devices its better to set a static ip that doesn’t change.
    The IP for the printer is usually set on the printer, using the menu, in versaworks you then enter the IP address for the printer, so versaworks knows where to look on the network.
    Hope that helps.
