Home Forums Vinyl Cutter Discussions General Cutter topics Advice needed running a Liyu vinyl cutter?
  • Advice needed running a Liyu vinyl cutter?
    Posted by stephen fleming on 10 June 2012 at 16:24
    Hello all I’m wondering if any kind person could help me out here,
    I’ve have recently purchased the above vinyl cutter and have it connected to my laptop via USB, I mucked around with the settings got it going after a short while, using signlab got 2 cuts out of it and then all i’m getting is port fault thingy, i’m unsure what i had the settings at. anyone had the same problem?
    Kind regards
    :police: Please take a moment to look over our Board Rules.
    stephen fleming replied 13 years, 5 months ago 5 Members · 7 Replies
  • 7 Replies
  • Neil Davey
    10 June 2012 at 17:27
    Hi Stephen, if you go to the Say Hello forum and introduce yourself, tell us a little about your background etc. you’ll probably find you’ll get help with your problem.
    By the the way welcome to the boards.
  • David Rogers
    10 June 2012 at 18:23
    It might also be worthwhile contacting either CADLINK for the correct driver or your plotter supplier.
  • Frank Droog
    11 June 2012 at 13:12
    I might be able to help. I write most of the drivers at cadlink.
    I would need to know the exact error message you are getting.
    Also would need to know the Version production date of your Signlab.
    You can find that in Help/About Signlab
  • Ian Johnston
    11 June 2012 at 13:42
    quote Frank Droog:
    i’d doubt with a £200 cutter that it’s a original version of signlab 😕
  • stephen fleming
    11 June 2012 at 14:22
    Hi all and thanks for the tips on what it could be, also i forgot to mention that its a demonstration version of sign lab I’m using I was told that a graptec driver would work on it, but unsure.
    Kind regards
  • Frank Droog
    11 June 2012 at 16:00
    Signlab 9 and probably 8 have a LiYu folder under File Install drivers.
    I would try those first.
    The Liyu SC sreies is supposed to understang DMPL and HPGL
    Is it a SC series cutter?
    Our Liyu drivers are DMPL drivers.
    We have some HPGL graphetec drivers.
    Try the Liyu drivers.
    Does it cut what it is supposed to?
    If there are error messages, what is the exact error message.
    What is the production date and version of your Signlab
  • stephen fleming
    12 June 2012 at 04:34
    Hi All
    Thanks for the great support i eventually got it going I found out that its compatible with a graphtec 5xxxx driver so it’s up and working as for the 200 pound cutter it’s doing the job.
    Again all thanks very much 🙂
    Kind regards
    Stevie
