Home Forums Software Discussions Adobe Software advice needed please with psd to vector files
  • advice needed please with psd to vector files
    Posted by paul beedham on 25 February 2013 at 15:57
    hi i made a logo in photoshop and wanted it printing the company said it had to be vectorized they did this within 10mins now i have my own print and cut mashine i want to print and cut some more but in need of some help i have followed videos on youtube but get to the last bit and icant go any futher there must be a simple way to convert this hope someone can help many thanks paul
    Moderator Edited to
    conform with Board Rules
    Nick Eccles replied 12 years, 9 months ago 9 Members · 13 Replies
  • 13 Replies
    25 February 2013 at 16:02
    Depends what software you are using but most will have some sort of auto trace or vectorising feature. Depending on software some are better than others but most will require some sort of manual editing to tidy them up for cutting.
    What software are you using at the moment.
  • paul beedham
    25 February 2013 at 16:25
    i used photoshop cs5 to make the design i also have illustrator cs5 aswell
    25 February 2013 at 16:43
    Well you would need to use Illustrator as that’s a vector based program, should be an auto trace on it somewhere for converting bitmaps to vectors.
    I do pretty much all my design work in a vector based program, makes it easier to scale plus I am a lot more familiar with that software. I only import into photoshop if I need to add effects that I don’t have in the other program
  • Colin Crabb
    25 February 2013 at 17:21
    Yup Martins spot on, Use Illustator CS4:
    ‘Object – Live Trace – Tracing options’
    In tracing options you can adjust to give best possible reslut, don’t forget to ‘expand’ afterward for ‘vectored’ image.
    If you have CS4 Suite, try to use Illustator for creating Logos etc, avoid Photoshop as this will create future problems and time wasted recreating previous work.
  • Neil Davey
    25 February 2013 at 22:41
    Be careful out there, I’m sure I saw the punctuation Police earlier!!!! 😉
  • Harry Cleary
    26 February 2013 at 00:03
    quote Neil Davey:
    We’ll have a whip round and buy him a bag of commas?
  • Neil Davey
    26 February 2013 at 08:42
    quote Harry Cleary:
    quote Neil Davey:
  • Chris Windebank
    26 February 2013 at 09:24
    you can print and cut a photoshop file, no need for vectorising. Your machine will print any image its the cutting path you need.
    What machine do you have?
  • Nick Eccles
    26 February 2013 at 09:40
    is it just an outline cut you need ?
    We have a Roland VS using versaworks, the way we do it is create a vector mask in Photoshop.
    Load the file into AI and set the stroke of the Vector Mask to the Contour cut spot colour, save as EPS then load into Versaworks and it prints and cuts fine.
    26 February 2013 at 10:38
    Having read the post again Chris I think your right, poster is just looking to put a cut path around a printer image, he would still need to do that in illustrator though wouldn’t he??
    26 February 2013 at 16:08
    quote :
    you have a vector image already so use the objects to create the outline
    or have i missed something
  • Simon Worrall
    27 February 2013 at 07:30
    quote Neil Davey:
    We are watching….
    Anyway. Back to the subject in hand. I have never had a usable result from a trace. Since you can very accurately vectorise most logos from scratch in less time than it takes to clean up the result of a trace, I don’t really see the point of them.
    Simon.
  • Nick Eccles
    27 February 2013 at 08:16
    quote Simon Worrall:
    Simon.
    I’m getting to a similar conclusion….. a way I’ve used quite a bit now is using the magic wand tool on Photoshop to create a path, create a vector mask from the path then load into AI very successful
