Home Forums Sign Making Discussions Vehicle Wrapping Advice needed, Plasti-Dip removal?
  • Advice needed, Plasti-Dip removal?
    Posted by Tim Cowlishaw on 12 September 2015 at 13:21
    How do you remove plastic dip Its not been sprayed thick enough to peel Comes off in small bits
    I have found a spray that says it can desolve it But its from the USA
    Any ideas would be helpful
    Tim Cowlishaw replied 10 years, 2 months ago 3 Members · 5 Replies
    12 September 2015 at 19:52
    Did you put it on Tim?
  • Tim Cowlishaw
    12 September 2015 at 20:25
    No not guilty
  • Kevin Flowers
    12 September 2015 at 20:39
    Pressure washer?
    12 September 2015 at 21:06
    in that case, charge by the hour for removal.
    advise heavily before using chemicals. if it dulls the paintwork or has any other adverse effect you will be expected to compensate.
    you also need to be aware if the vehicle has had any re-sprays or touch ups. again, your removal may create problems. this is just the norma, same applied on removing vehicle wraps.
    personally, i wouldn’t get involved. 😕
  • Tim Cowlishaw
    12 September 2015 at 21:26
    Haha Felt it was a walk away job Thanks alot 😀
