Home Forums Sign Making Discussions General Sign Topics Advice needed on Roll-up stands please?
    5 March 2013 at 14:57
    Yes… depends on the style.
    If its the cheap(er) stands, one end will have flat pin, the other a round pin.
    Unscrew the plate with the flat pin, then re-tension the spring inside by turning it (using the plate to turn the flat headed pin, in a clockwise (I think) Direction) keeping hold of the plate screw it back into place.
    You can then pull the graphic out, and insert an allen key, or small drill bit into the hole in the side to lock it.
    5 March 2013 at 17:29
    thanks dave
    do i put the side pin in first as i tension it then remove it to pull the graphic out, then put the pin back.
    6 March 2013 at 13:37
    Sorry Chris, I never got an e-mail to say you replied and I’ve been out all morning.
    I would think that would work… and might actually be easier than my method, especially if the locking pin goes in the side with the round pin, rather than the flat.
    6 March 2013 at 20:41
    thanks david might have done it wait till i have a graphic to put on it,
    i did a deal so the customer has nice new ones but wanted to keep these if repaired for our selfs.
