Home Forums Vinyl Cutter Discussions Roland Cutters Advice needed on Roland Camm 1Pro Cutter please?
  • Advice needed on Roland Camm 1Pro Cutter please?
    Posted by Jarrard Harrison on 23 October 2012 at 18:56
    good evening all, my names is Jarrard and I run St Ives Signs in Cornwall, . I have a Roland Camm 1Pro cutter that is over 10 years old and today we got some material stuck in it, we removed the material with now evidence of anything stuck, I have no material width recognition, I get a message " change pinch roller position". I have cleaned and checked all fittings, wires etc,,,
    Would look forward to some advise
    Jarrard
    Jarrard Harrison replied 13 years, 2 months ago 4 Members · 10 Replies
  • 10 Replies
  • Neil Davey
    23 October 2012 at 19:44
    Hi Jarrard, bit of an abrupt opening post!!!!
    I think if you took the time to introduce yourself in the Welcome Forum and tell us a little about yourself you may get the help you command 😉
  • Jarrard Harrison
    23 October 2012 at 19:52
    Cheers Neil for the advice,,, new to this !!! I’ll change my post !
  • Neil Davey
    23 October 2012 at 20:02
    Well done Jarrard, I’m sure you’ll get a better response if you take the time to say hi 😀
  • Frank Droog
    23 October 2012 at 20:25
    you do know you can slide the pinch rollers to the left and right for differant widths of vinyl and that they can only be in certain positions.
    1/4 inch too much in either direction and you get that error.
    are the pinch rollers on a smooth part of the grit roller or on a gritty part?
  • Jarrard Harrison
    24 October 2012 at 06:00
    Morning & thanks for the reply.
    I have had this machine from new, 1st problem in over 10 years.
    it’s not the position of the pinch rollers as they are correct to view, is there anything else on the cutter that senses the width,?? Thanks Jarrard
  • Tim Painter
    24 October 2012 at 08:00
    Behind the pinch rollers you have small blocks sat in a recess.
    Not sure what they are possibly magnets.
    On a 3 roller machine only the outside ones have these.
    Are they all there or maybe been knocked out?
    or possible damage to the pinch roller sense board on the cutting head or any wires disconnected from the cutting head.
  • Jarrard Harrison
    24 October 2012 at 08:22
    Hi Tim
    Thanks for your help..
    Mine is a two pinch roller, I think it must be the small circuit board at the back of the cutting head, take it its the sensor,,, there are no wires loose.
    Thanks for your help, is this a Roland part or are there aftermarket suppliers for small parts like this ??
    Jarrard
  • Tim Painter
    24 October 2012 at 08:34
    Roland part only I would say.
    Probably worth a call to Roland to see if you can test it before ordering anything.
  • Jarrard Harrison
    24 October 2012 at 08:38
    Thanks Tim
  • Jarrard Harrison
    24 October 2012 at 08:53
    Yep Roland Part £12.50 + vat & Delivery
