Home Forums Sign Making Discussions Neon, LED, Lighting Advice needed on Flat Cut Letters please?
  • Advice needed on Flat Cut Letters please?
    Posted by David Mitchell on 2 December 2013 at 16:39
    im a newbie so bear with me folks,
    how are flat cut acrylic letters made.
    i kinda assum with a cnc router?? if so how much would one set you back.
    i know you can buy letters online etc but just out of curiosity …. for now 😛
    mod-edit please use descriptive topic titles
    see board rules
    David Mitchell replied 12 years ago 4 Members · 7 Replies
  • 7 Replies
    2 December 2013 at 16:53
    depends on CNC machine, make, what you want to cut etc.
    haven’t looked in a look time, but guess your looking at £15k upwards.
    Obviously cheaper models available from the USA and the like.
    however, have a look at phill fentons in-depth tutorial on creating your own, he built one in-house for around £600 and has been producing work on it since.
    http://www.uksignboards.com/viewtopic.php?t=56308
  • David Mitchell
    2 December 2013 at 16:56
    thank you robert, and apologies for the need to edit 🙂
    membership is the next thing on the list!
    2 December 2013 at 20:11
    Like Robert says a decent machine will set you back a lot of money if bought new & even good second hand machines hold their price quite well. Quite a few scams going about on places like ebay so beware of that. Also a lot of the cheaper chinese machines are pretty bad from what I have read on other forums
    Other option depending what sort of skills you have is to manufacture one from scratch as Phill did or buy one that’s knackered & rebuild it as I did.
    As well as the machine you may have software to buy to be able to use it which is another learning curve.
    They take up quite a bit of space so you need to plan for that.
    3 December 2013 at 10:09
    Yes it’s true – you really can build your own low cost machine that’s capable of producing accurate work. But you will need to invest some time in learning how to do it and following instructions from others that have written about it both in forums and in books. A good forum to look at is:-
    http://www.buildyourtools.com
    It really is a fascinating hobby and I guarantee you’ll be hooked once you start.
    I’m currently working on a design for a new machine using all aluminium components for the chassis and gantry which should yield a big improvement over wooden or mdf home built versions.
    However, not everyone would want to spend the time and effort building their own and good machines are available off the shelf from a number of manufacturers. A good quality second hand machine can probably be bought from about £5000 upwards
    3 December 2013 at 11:31
    Phill, did you ever get the machine to cut acrylic ? Just that acrylic letters were mentioned in the original post.
    3 December 2013 at 15:51
    Hi Martin
    Yes it will cut acrylic. But a better (polished) finish can be achieved using a laser cutter.
  • David Mitchell
    3 December 2013 at 16:22
    thanks guys, wonderful bunch on here 😛
