Home Forums Vinyl Cutter Discussions General Cutter topics Advice needed – fastrack 1300 Plotter
  • Advice needed – fastrack 1300 Plotter
    Posted by adrianth on 2 August 2016 at 13:27
    We have a Fastback 1300 plotter that is a number of years old & when we turned it on this morning, it attempted to move the plotter head but stopped & all the red lights came on. After doing the usual turn off / on etc, we went through the error code procedure & were informed it was a ‘MOVING COIL A/D FAILURE’. I spoke to Spandex & they said, potentially the Pen Head Assembly Second Version was defective.
    Any thoughts would be much appreciated.
    Peter Whitehead replied 9 years, 3 months ago 1 Member · 1 Reply
  • 1 Reply
  • Peter Whitehead
    16 September 2016 at 16:58
    I hope your ok, have you got your fastrack problem sorted out, or have you still got a problem with it. when you got the error did you take the display of leds and get the error code from the manual.
    if it is a moving coil error it probably is the head.
    let me know how you are getting on
    regards
    pete
