Home Forums Sign Making Discussions General Sign Topics Advice fixing sign frame to cladding
  • Advice fixing sign frame to cladding
    Posted by David Hammond on 19 May 2012 at 13:25
    Got 2 jobs on that will require a sign frame fitting to metal cladding.
    I assume I’d be best using cladding screws?
    Just not entirely sure what I require… My other thought is, will water seep through the screw holes, or should I use rubber washers to seal the gap?
    Robert Lambie replied 13 years, 7 months ago 3 Members · 5 Replies
  • Stuart Miller
    19 May 2012 at 15:25
    Self drilling Tek Screws.
    You can get them with a rubber washer and I have taken the washer off and put it between frame and Cladding where necessary.
    http://www.screwfix.com/p/roofing-to-steel-bzp-5-5-x-25mm-pack-of-100/33545
    19 May 2012 at 15:30
    buy tech screws. get the ones that come somplete with rubber washers. factory cladding does not rust anyway, the rubber washer allows movement and seals the hole at the same time.
    various sources sell tech screws and prices vary. screw fix arent the best on price but lets you get hold of them quickly. http://www.screwfix.com
    you will only need them to be about an inch long.
    use only "full thread" version. i.e. the thread runs length of screw
    you WILL Need a tech bit (see picture below)
    dont buy star screw head versions, get the Hex-head, much easier to work with.
    if your using a panatrim type frame, you may not get a tech screw in the space unless your using techs without the rubber washer.[/u]
    :lol1: you beat me to it Stuart! 😉
    20 May 2012 at 16:40
    Cheers guys.
    I wasn’t sure if the head would stop the panel fitting.
    Will get some from screw fix or toolstation next week.
    20 May 2012 at 20:55
    there is a lip on the trim that stops the fixing hitting the panel when slid in.
