Acrylic wall fixings
Hi All
I have a large menu board to erect and would like to know the best way to fix it. It is on to a tiled wall and the size of the acrylic sheet is 950mm wide by 1620mm high (5mm acrylic)
Grafityp do a product called "stronghold small sign fixings" but what is considered a small sign, or can you get bigger fixings like these for larger signs? If these are OK to use how many would I need to put along the 1620mm length to ensure it is well enugh supported and won’t bend in the centre.
What is the best method to mount and where can I get it from?
Warren
