Home Forums Sign Making Discussions General Sign Topics Acrylic to wood adhesive?
  • Acrylic to wood adhesive?
    Posted by A.Kordowski on 12 December 2018 at 11:30
    I’ve got some cut acrylic letters to stick to a wood fascia and not to sure what glue to use any suggestions….thanks in advance.
    Andy
    David Rogers replied 7 years ago 2 Members · 2 Replies
  • Simon Worrall
    12 December 2018 at 19:17
    Heres how I do it:
    1. Roughen the back of the acrylic letters –
    2. cut out a stencil from Oracal 810 and apply to the substrate
    Smear SIROFLEX adhesive all over where the letters are to go. You can use a teflon squeegee, and use the thickness of the stencil as a "guide" for the thickness of the adhesive that is laid down.
    Press the letters into the spaces. Leave overnight.
    When you come back, pull the stencil away, and if you have done it right there wont be any glue visible.
    You can also use VHB tape, but the individual pieces show when you look down the side of the letters.
  • David Rogers
    13 December 2018 at 09:06
    Is it wood (bare, untreated) or painted?
    If bare – had success with some thick VHB tabs to hold it in place and Evo Stik ‘serious stuff’ which is a rubbery adhesive. Not had anything fall off yet (using it for years).
    Also works for painted surfaces and as said roughen the back of the acrylic.
