Home Forums Sign Making Discussions General Sign Topics acrylic fitting, need help!
  • acrylic fitting, need help!
    Posted by Andy@Acorn on 16 February 2004 at 12:17
    Help got a panel of acrylic 3000mm x 750mm to put up onto a cladded factory, needs to be rasied off. Think its going to be to hard to use locators, anyone got any ideas (?)
    Simon Clayton replied 21 years, 9 months ago 4 Members · 4 Replies
  • fluidedge
    16 February 2004 at 12:35
    Would a frame help?
  • Nigel Fraser
    16 February 2004 at 13:58
    Andy,
    Could you use the stainless stand-offs like the these – http://www.e-shopfittings.com/display2. … =SFittings
    Or failing that, just use a couple of runs of 2″ alu angle along the long length and two more fixed to the building, then screw through from the top and bottom.
    Nigel
  • Lorraine Buchan
    16 February 2004 at 15:40
    I’d go with Nigels idea of a couple of bits of ali angle
  • Simon Clayton
    16 February 2004 at 18:00
    Something like this i would use a frame..perspex expands and contracts quite a bit and is brittle.
    Or go for the metal type panels (luca bond) spayed to match.
    Simon
