Home Forums Sign Making Discussions General Sign Topics Acrylic cutting?
  • Acrylic cutting?
    Posted by Ryan Fairweather on 23 April 2007 at 10:59
    Hi everyone,
    achieved a good cut on a big piece of Acrylic but was wondering if you know of a way of removing the slightly blemished sides?
    Can you apply heat to remove the slightly glazed look to make it more polished?
    thanks in advance
    Rodney Gold replied 18 years, 8 months ago 7 Members · 12 Replies
  • 12 Replies
  • Fred McLean
    23 April 2007 at 11:13
    Is it clear acrylic?
  • Andy Gorman
    23 April 2007 at 11:14
    If you flame polish coloured acrylics there is a chance of it going a bit milky, clear is fine.
    If I want a neater edge, I scrape the edge with a piece of steel, first along the corners of the edge then along the flat. This gets rid of saw marks. I use half of a pair of scissors. You can then use wet-and-dry if you want it really smooth.
  • Ryan Fairweather
    23 April 2007 at 11:20
    yes, its clear
  • Fred McLean
    23 April 2007 at 11:25
    Scraping with steel the way to go 😀
  • Kevin Flowers
    23 April 2007 at 20:08
    I use a steel ruler works well because of its nice finished edge
  • David Rogers
    23 April 2007 at 20:15
    Posted this before.
    http://www.uksignboards.com/viewtopic.p … ight=flame
    What I personally use to scrape the edges is a stanley blade OUT of the knife, then flame polished. Can also wet’n’dry with the finest grade, then polish up with brasso & a buff. Works a treat.
    24 April 2007 at 00:22
    Ryan, how did you cut the board in the first place? Materials like acrylic should really be cut with a negative rake blade which should give you a pretty good finish everytime.
  • Ryan Fairweather
    24 April 2007 at 08:16
    Yes, did that thanks. Followed the manufacturers cutting instructions but just wanted to add a better overall finish to it.
    I scraped it with a steel edge yesterday and i am really pleased with the result.
    I think i will experiment with the flame polishing on an off cut as well.
    thanks for all the help guys 😀
    24 April 2007 at 09:41
    Depends what it is for Ryan, to be honest with you I havent tried flame polishing myself and didn’t know about the steel rule trick, when I have used acrylic before I have cut it myself if it is going in a lightbox or a frame where the edges won’t be seen but when I have done stuff with a visible edge I had it supplied cut to size to ensure there were nice edges on it. Will have to have a go at both methods sometime but to be honest I didn’t use to use very much acrylic other than for lightbox panels at all.
  • Rodney Gold
    24 April 2007 at 16:18
    If you flame polish and use ANY solvent or glues on the acrylic or even if its near solvents , you are almost guaranteed to get stress cracks , be aware of this.
    24 April 2007 at 16:23
    Rodney, thats something well worth knowing cheers. I take it from what you have said that would include the adhesives used with vinyls. So it wouldn’t be a good idea to make up a panel for wall mounting using say frosted crystal if you had flame polished the edges of the acrylic.
  • Rodney Gold
    24 April 2007 at 19:39
    No m vinyl adhesive are fine , its stuff like meths , screenprinting inks ,acetone , thinners, chloroform , methyl chloride , solvent based glues etc that will give problems. Will happen with any process that puts heat into Acrylic.
