Home Forums Sign Making Discussions General Sign Topics acrylic corners ! to protect plaster wall edges
  • acrylic corners ! to protect plaster wall edges
    Posted by Derek Heron on 9 November 2006 at 19:21
    not sure where to post this so sorry mods
    i have been asked about the following
    acrylic corners these are to protect the edges of plastered walls in a police station apparently the standard edges are bashed all the time by truncheons etc.
    they have to be 1.1 metres high with at least 50mm either side pre drilled to fix with at least 3 points either side
    does any body have any contacts with anyone who can do this
    or know of anything already on the market . not necessarily acrylic
    i need 25 to start with.
    thanks
    Derek
    David Rogers replied 19 years, 1 month ago 3 Members · 3 Replies
    9 November 2006 at 20:03
    Derek,
    I found this, dont know them, but seems to be what you need.
    http://www.dominoplastics.co.uk/sproducts.htm
    Or alternative, get some stainless bent at your local metal fabrication shop, it may be a tougher alternative.
  • Derek Heron
    9 November 2006 at 21:04
    thanks peter wasn’t sure if i explained it right but they are exactly what i was on about i am glad some one understands me
    will ring them a.m
    thanks again.
    Derek
  • David Rogers
    9 November 2006 at 21:44
    Try a plastics stockist or fabricator. (Stockline Plastics?)
    You can get PVC 90 degree angle (white only) in various sizes. I’ve used it as corner protection on occasions. Just a bead of Evo "serious stuff" and press into place.
    Alternatively, an aluminium extrusion stockist (Righton) and get some 90.
    At a push get some polycarbonate (or stainless as suggested) & have a local firm cold bend it.
