Home Forums Sign Making Discussions General Sign Topics 651 RED vinyl with text on it… Where would you get this?
  • 651 RED vinyl with text on it… Where would you get this?
    Posted by Stuart Drynan on 7 March 2013 at 11:45
    I have been supplying load lines for a job we are doing for a few months now and we have to fit a 33mm wide load line in red with the text "DO NOT LOAD ABOVE THIS LINE"
    I have printed this but it stretches to much
    Supplied it in cut strips of 1200 long with cut text on it and it works but then i have joins all the way along the line 🙁
    My plotter refuses to cut consistently over anything longer than 1.5mtr so doing it in one length is out the question.
    The average length i need is around 9.5mtrs…
    Is there somewhere that I can buy a pre-made roll with the text on it?
    Or is this something that a screen printing place would offer?
    Last option is to have a roll of vinyl (50mtrs) cut to smaller widths of 33mm and apply the text my self on site but for speed and easiness an all in one solution would be best.
    What are peoples thoughts on this one?
    Stuart Drynan replied 12 years, 9 months ago 5 Members · 8 Replies
  • 8 Replies
    7 March 2013 at 12:29
    What plotter are you using stuart? If your having problems with anything over 1.5 mtrs then there’s something seriously wrong with either the plotter or the way you are loading the vinyl & squaring it up. 9.5 mtrs may be a push but 5 or 6 mtrs shouldn’t be a problem if it’s set up correctly.
    7 March 2013 at 12:30
    I think if you approach someone like Robert horne and ask nicely, they’ll cut the roll at you widths, I’ve done it with 20m roll before now, needed two 10m x 25mm strips so bought 20m and had them slice off a couple of 25mm bits, very useful and still a very usable roll left over.
    as for the text, I’d cut that seperately and apply after.
    Hugh
  • Stuart Drynan
    7 March 2013 at 12:34
    martin:
    Our jaguar plotter is getting old 🙂 it just refuses to go over 5mtr without running off.. Issue isnt that it runs off over one cut, but we can be running up to 10 from one bit of vinyl. then it causes the machine to run off.
    Also been trying to use our mimaki and roland but same issues…
    Both completely square on set up..
    I think if i cant buy them in pre made then its the manual application route 🙂
    cheers guys
  • Chris Wool
    7 March 2013 at 15:52
    quote :
    think i might give this more thought as you get to put the lettering where its meant to be.
  • Stuart Drynan
    7 March 2013 at 16:00
    I have contacted RH and awaiting a price and wither they can supply me the material pre cut into 50mtr rolls of 33mm wide red 🙂
    If they can do that then it saves me having to get a local place to try cut it for us 🙂
  • Chris Wool
    7 March 2013 at 16:10
    i have had 10mt rolls cut down to seveal strips from spandex think it was 4 cuts free then £2 a cut
  • Gary Birch
    7 March 2013 at 16:14
    quote Stuart Drynan:
    Robert horne have done part rolls down to 39mm for us so i see no reason why not.
    Gary
  • Stuart Drynan
    7 March 2013 at 16:17
    Good to hear 🙂
    Im off till monday from tonight so hopefully when im back i have a message saying yes 🙂
