Hi Paul, good to see you back on the boards mate, thats number three old school uksb member posting again within a week! :lol1:
Price per linear metre supply only.
Price per linear metre Laminated Supply only.
Installation cost by the hour x 2-3 men.
if the job is unlaminated you will need the same in application tape or you will find the vinyl will snap in the cold.
dependant on the surface you are applying too, the vinyl, even if laminated, may also shatter in the cold. when i say shatter, i mean simply break apart.
when i say surface, i mean if its a metal. this being the case the vinyl will stick on contact, but if you try lifting it in any way it will simply break leaving the part that made contact still stuck to the surface.
Years ago we did a couple of hundred metres of cut vinyl text about 4ft high and fitted onto a "corrugated wall" in an Ice Curling Centre. same scenario as you with temps etc. so the above is all relevant. all we had in our favour was the corrugated wall was plastic. so the surface temp wasnt as cold as metal will be.
The cold temperature should repel contact adhesion making dry application much easier. but i have seen it have opposite affect and stick first touch.
I am not sure how your application skills are but i strongly suggest doing a test run. dont just arrive and apply, leave the media in the room for 20 minutes before applying. this will give a more realistic test than walking in with warm vinyls.
I have never tried the following but have heard it works because rapid tack has adhesive stimulants in the fluid. click video below.
<embed width=”452″ height=”361″ quality=”high” bgcolor=”#000000″ wmode=”transparent” name=”main” id=”main” allowfullscreen=”false” src=”http://www.isigntube.com/player/vPlayer.swf?f=http://www.isigntube.com/player/vConfig_embed.php?vkey=295f8076b1c5722a46aa” type=”application/x-shockwave-flash”>
