MUTOH Introduces XpertJet C641SR Pro Printer/Cutter
MUTOH Europe nv, the EMEA headquarters for MUTOH INDUSTRIES LTD., Japan, introduces its first-ever integrated print and cut device, the XpertJet C641SR Pro, a 24” (630 mm) wide model. The XPJ C641SR Pro offers precise contour-cut and through-cut functionality and integrates a MUTOH AccuFine 1600 nozzle print head, enhancing both print quality and productivity. The new model is ideal for desktop use, but can also be equipped with a stand on caster wheels and an automatic roll-up device for added versatility.
Offering a quality production print speed of 6.5 m²/h at 600 x 900 dpi, the printer/cutter includes the advanced user comfort features known from the award-winning XpertJet SR Pro 54” and 64” wide printer models and uses MUTOH’s GREENGUARD Gold certified MS31/MS51 inks which are suited for a wide variety of outdoor and indoor graphics.
Engineered and assembled in Japan, the XpertJet C641SR Pro is a compact, lightweight printer/cutter designed for businesses starting out or bringing graphics and sticker production in-house. It’s versatile for creating signs, full-colour stickers, vehicle graphics, banners, posters, labels, heat transfers and fine art prints.
Contour Cut and Through Cut
The XpertJet C641SR Pro integrates a drag knife cutting head for precise contour and through cutting. Two adjustable pressure arms allow accommodating various media width ranges. A built-in grit roller ensures accurate media transport and alignment.
XpertJet C641SR Pro – Product Highlights
- MUTOH’s first ever integrated print & cut model – 630 mm – 24” wide
- Ideal for desktop usage – stand on casters & automated take-up system (10 kg) for continuous printing available.
- Contour and through-cutting: features a drag knife cutting head, a grit roller, repositionable pressure rolls and a cutting mat for continuous or separate cutting.
- Printing and cutting with VerteLith, MUTOH’s genuine RIP software:
- Built around Harlequin® RIP Core
- Straightforward & powerful user interface
- Simple workflow
- Powerful preview functions to reduce errors and waste
- Workflow efficiency & finishing tools (trim marks, grommets, automated and manual tiling, step & repeat functionality, accurate multi page PDF processing)
- Integrated sheet off mechanism for roll-to-sheet and sheet-to-sheet applications.
- AccuFine 1600 nozzle print head on board. MUTOH’s AccuFine print head technology ensures precise nozzle alignment, faster printing and high-resolution output (up to 1200 x 1200 dpi), enhancing both print quality and productivity.
- Quality production print speeds (600 x 900 dpi) : 6.5 m²/h
- New generation i-screen weaving technology suppresses banding even further.
- GREENGUARD Gold certified MS31/MS51 inks :
- Output can be used at full room coverage, even in sensitive environments such as schools and hospitals.
- UV durability without lamination up to 3 years outdoor. For heavy duty applications where mechanical stress or environmental impact is involved (floor, vehicle and marine graphics), lamination is required. Stabilisation is required prior to lamination.
- Unrivalled user assistance to save time and waste :
- Drop Master : Automated bi-dir alignment.
- Feed Master : Automated media feed adjust.
- Media Tracker : Automated media roll length management through bar code print/scan
- Nozzle Area Select : Allows disabling of nozzle areas on the head to continue printing.
The product will become available later this year through MUTOH certified distributors and partners.
Responses
