Home Forums Sign Making Discussions Off Topic Chat Supplier of Plastic Letters and Numbers
  • Supplier of Plastic Letters and Numbers
    Posted by Darrell Wootton on 8 December 2004 at 19:15
    I am looking for the manufacturer of the following plastic letters:
    Does anyone know who makes them, please.
    Many Thanks
    Darrell…..
    (edit-admin)
    ian hobbs replied 20 years, 10 months ago 7 Members · 11 Replies
  • 11 Replies
  • Adrian Hewson
    8 December 2004 at 22:58
    Hi Darell
    This enquiry is currently going round all the big sign companies, these letters I guess are screen printed onto 1mm rigid plastic.
    join the lsit quoting by seeing your local screen printer
    Regards Adrian
  • Bill Dewison
    8 December 2004 at 23:43
    Can you not just vinyl them onto 1mm stuff? Be fairly cheap to do.
    Cheers, Dewi
  • Andy Gorman
    9 December 2004 at 00:08
    My thoughts exactly. Can’t remember what it’s called, but there’s a rigid pvc (not foam, more dense) that comes in thinner sheets. Robert Horne probably sell it. Anyway, anyone with a plotter could do that job.
  • Rebecca
    9 December 2004 at 00:17
    We would use huntsman high impact polystyrene (Robert Horne/A&P Display) either in 1000 micron or 1500 micron
    Rebecca
  • Andy Gorman
    9 December 2004 at 00:21
    That’s the word I was looking for: polystyrene!
    Darrell, if the method we are talking about is acceptable, feel free to e-mail the details; I’ll have a look at it for you.
    I hope I’m not breaking any rules here Rob. Apologies if so.
  • Darrell Wootton
    11 December 2004 at 04:31
    Hi BigG
    I am not sure of the material, however doing some research the US web sites are selling the digits as part of a readerboard system?
    At the moment I am not sure of the amount of letters needed.
    Its for a scoreboard that needs to cater for 192 players with the following categories per player:
    Card Size: 25mm Wide x 55mm Height (Approx)
    Digit Size: 15mm Wide x 30mm Height (Approx)
    Position: (1-192)
    Surname (For 192 Players) (Black on Yellow)
    Rnd 1 Score (0-99) (White on Red)
    Rnd 2 Score (0-99) (Black on White)
    Rnd 3 Score (0-99) (White on Blue)
    Rnd 4 Score (0-99) (Black on White)
    Total Score (0-999) (Black on White)
    Category Headers (for the above categories) x 2
    Main Board Headers x 2 (White on Navy)
    So I need enough letters and number to cater for all 192 players names and score combinations and the material needs to be used outdoors!
    I am trying to get hold of the client to ask how many letters and numbers they need!!.
    Do you work on a per digit price or supply in packs?
    Darrell…..
  • ian hobbs
    4 January 2005 at 10:03
    the product i think you are looking for is a spandex material called plastigraphix…but robert horne do a similar pvc in sheet form not sprocketed.
    hope this helps
    ian
    4 January 2005 at 10:13
    Rebecca is right to suggest HIPs material.
    I do a bit of these. I cut the letters with a border the overall size required. I then use the border as the cut edge. HIPs will cut with a stanley knife no worries.
    If I am doing a lot as there are here, I’d get the material cut to size by the supplier.
    Pretty easy job really, but you’ll be sick of it by the end 🙄 Low material costs but a high labour content.
  • Bill Dewison
    4 January 2005 at 13:07
    I could have sworn Europoint display do that 1mm foamboardy stuff, it is like a rigid plastic, but its cool for doing flexible signs that you need to bend into place.
    As has been said, really easy to cut, but its a little unforgiving if you slip with the blade. I had to recut the same piece 3 times, wasted loads of material, and all because I didn’t use a non-slip rule 😳 If there’s an expensive way to learn, I’ll find it 😳
    Cheers, Dewi
    4 January 2005 at 13:17
    quote Dewi:
    Cheers, Dewi
    Dewi, you have such a way with words :lol1:
    The ‘1mm foamboardy stuff’ we have here is called expanded foam PVC (ePVC) and it is just as Dewi says, but beware, it comes in 2 different styles (here anyway) a UV version and a non UV version. Get the wrong one and it will fail outside really quickly.
    It is a good replacement for HIPS as it is easier to cut, but the price is much the same.
  • ian hobbs
    4 January 2005 at 13:18
    plastigraphix also goes through the edge and plotter, so just snap and crack out the shape once printed and cut..
    cheap as chips!
