Posted by David.Smith on November 18, 2014 at 11:44 am
Hi all, our summa 120D has suddenly decided to only cut at 100mm/s. Got it set at 700 on the cutter and the same on signblazer and signlab but it still only cuts at 100, any suggestions most welcome before I sling it out the window?
David
you could try doing a factory reset believe you can do it from menu settings, at least it will tell you if its just a setting on the cutter that been altered accidentally or a problem with the cutter. The fact that more than one type of software is giving the same result does point to cutter. Have you a manual if not you can get it here
Please note:
