Home Forums Printing Discussions General Printing Topics scoring in gloss laminate?
  • scoring in gloss laminate?
    Posted by Ruairi O'Boyle on 30 April 2013 at 21:24
    We recently hand applied a printed graphic to composite board using a felt squegee. The top suface was metamark gloss digital laminate. I wet the surface to minimize friction but when we installed the sign and the client has complained about small score marks in the surface. Unfortunately it is directly below flourescent lighting which makes it look worse. What can i do to stop this happening the next time round?
    Chris Windebank replied 12 years, 6 months ago 4 Members · 5 Replies
  • Kevin Flowers
    30 April 2013 at 21:47
    gloss is a pain for this i use the backing paper put on top of the laminate, the silicone side allows the squeegee to glide quite freely
  • Ruairi O'Boyle
    30 April 2013 at 21:50
    Thanks Kev I will give that a try. I should have run it through the laminator but the print had no bleed design and left me needing to run it very exact as it was across 2 seperate panels.
    30 April 2013 at 22:00
    You can get rid of the scratches by polishing the surface using "t" cut
  • Ruairi O'Boyle
    1 May 2013 at 06:05
    Cheers phill – ill give that a go later.
  • Chris Windebank
    1 May 2013 at 07:15
    also worth trying a heat gun as the laminate relaxes a little and scratches seem to flow out.
