Activity Feed Forums Sign Making Discussions General Sign Topics Removable vinyl installation in a busy shopping mall. Yes or No?
  • Removable vinyl installation in a busy shopping mall. Yes or No?
    Posted by Pane Talev Pane Talev on June 15, 2020 at 5:45 pm
    Evening all,
    I need to print 3m x 5m print and apply this on face of the glass / shop. (so pass byers can touch / feel / peel this print)
    Print needs to come down in 30 days. I’m removing it.
    Planing to do this job with "Orajet 3628 super removable"
    "Orajet 3628 super removable" or normal mono?
    The reason I ask is: I dont want pass byers to easy remove / damage vinyl.
    Pane Talev Pane Talev replied 3 years, 3 months ago 5 Members · 10 Replies
  • 10 Replies
  • Graham Scanlan
    June 16, 2020 at 5:56 am
    Hi Pane
    Read the spec of the standard removable and you may find that there is no guarantee for adhesive free removability, so there maybe some glue removal required. With the ultra removable you should get adhesive Free removability
  • Pane Talev Pane Talev
    June 16, 2020 at 6:24 am
    quote Graham Scanlan:
    Hi Pane
    Hi Graham,
    It is not a problem if I need to clean up after I have removed the print. I’m more than ok with that.
    My main worry is the performance of the "Orajet 3628 super removable" during the time print is up / applied on the outside of the store.
  • Graham Scanlan
    June 16, 2020 at 8:11 am
    If the glue residue isn’t a problem go for the standard removable, that should put up with the knocks and bangs. I’m sure the ultra removable would work fine also but I guess could be more prone to being picked at especially if there are overlaps
  • Martyn Heath
    June 16, 2020 at 8:24 am
    Hi pane.
    Cant see why anyone would peel the print off the glass but for your piece of mind you could seal the edges by running a 20mm strip of normal vinyl around the edge of the print to seal the removable vinyl?
    June 16, 2020 at 1:58 pm
    A word of warning, check with the shopping centre, that they allow vinyl/graphics on the external window.
    From experience, some don’t.
  • Kevin Mahoney
    June 16, 2020 at 2:28 pm
    Also you will need millions on yourliability insurance & lots of data sheets for fire regs
    June 16, 2020 at 2:31 pm
    quote David Hammond:
    Got everything in writing to install on the outside.
    June 16, 2020 at 2:33 pm
    quote Martyn Heath:
    Hi pane.
    That will make it looking less sharp and tidy, so I will not go down that route.
    June 16, 2020 at 3:30 pm
    Who’s writing? We had a client say the same, their client said the same. Shopping centre said no.
    Your covered with it in writing, just saves you the headache.
    Regards removable, I’ve found they stick just as well as permanent adhesive, its only when you come to remove it, you really notice the benefits.
    You could stick some perm laminate over any joins, and slit when you come to remove.
    June 16, 2020 at 4:48 pm
    I hope so David. No joints, so that’s a plus.
    Thank you all.
