Activity Feed › Forums › Printing Discussions › Printer Ink › ink problem…my black ink going into the magenta damper
Posted by Alieu Cham on July 31, 2012 at 5:56 amHello ,,,,,,, please help me with advice my machine is jv3 160s machine…. and my black ink is going into my magenta damper which is making the magenta to prints black and also same problems with my yellow head printing blue because the blue ink is fellowing into the yellow damper.
thanx
AlieuAlieu Cham replied 11 years, 8 months ago 4 Members · 9 Replies -
:police: Mod-Edit
* Please Introduce yourself to our community properly by using the "Say Hello" forum.Please note: It is FACT, that those using their full proper name accompanied by a Profile Picture and have
introduced themselves to our community get far more replies and help with posts that they make than those without.
It also helps keep UKSB the friendliest sign forum we know of!Please also take a moment to look over our Board Rules.
That will probably be your pump not locking off properly and causing the ink from the cap to run back up the ink line.
You will probably get more replies if you introduce yourself in the correct section of the forum first.
Stafford
let us know if u have a pool of liquid in the capping station under the first head
Yes Dave there is lots of ink/liquid there
quote Dave Rowland:let us know if u have a pool of liquid in the capping station under the first head -
please accept my apologies.
i did change the pump but its still happening..
thank youquote Stafford Cox:That will probably be your pump not locking off properly and causing the ink from the cap to run back up the ink line.You will probably get more replies if you introduce yourself in the correct section of the forum first.
Stafford
you may have to check pressures with syringe, sounds like new pump is not able to pump (blockages)
Thanks Dave,
just to explains more concerning this problem,,,,,,
went am printing a box sample of only yellow …the outcome will be yellow mixed with lots of blue …..until you cannot see the yellow…
and if am printing box of red, the black ink will overcome the red……are you suggesting to change both pump.
quote Dave Rowland:you may have to check pressures with syringe, sounds like new pump is not able to pump (blockages) -
quote Dave Rowland:yep thats correct…. u are blocked
Hello Dave,
can you help am still having same problems….please send me your email address to chat more as concern…
this is my email chamjerrejeff@gmail.com
