Home Forums Printing Discussions General Printing Topics DX5/DX7 capping station lifespan?
  • DX5/DX7 capping station lifespan?
    Posted by John Thomson on 26 June 2013 at 15:37
    how long should a capping station last?
    I have went through 2 in six months…….just losing their sealing ability resulting in a poor test print pattern.
    My Mimaki with DX4 heads has had one capping station in 5 years.
    I would be interested to hear how long these should last…….do some suppliers sell better or longer lasting capping stations.
    john
    Reza Faezi replied 12 years, 4 months ago 5 Members · 5 Replies
  • Robert Walker
    26 June 2013 at 17:13
    I’ve just replaced mine on my VS hadn’t been done since I bought it 3 years ago
    26 June 2013 at 17:50
    interesting
    on my vs because it has white and silver it will tend to block the pipe work not the actual seal or foam bits.
    when i did a manual clean the other day this time using a mirror and a bright light i noticed a build up on the edges of the head which took a bit of shifting. this would have been affecting the seal. and i would not have noticed it with out the mirror.
    other thing i do is as the head uses the capping station as a spit area and the pump sucks it dry about every 30 or so passes of the head i add a little cleaning fluid to the pad, not in normal printing but if using white or silver just to thin the deposits.
  • John Thomson
    26 June 2013 at 21:20
    What I am trying to work out is are some better than others? …..if so which supplier is good…..
    My printer is an import and the manufacturer reckons 3-6 months lifespan for their capping stations is normal.
    Switching the capping station is easy and the oems are less than half the price of Digiprints non oem offering.
    I tried non oem on my DX4 head Mimaki and could not get a good seal so reverted to the much more expensive genuine capping station.
    If this is the same with the DX5/DX7 unit where do I get a better quality longer lasting unit?
    john
  • David.Smith
    26 June 2013 at 21:41
    I know this doesn’t help your question but I tend to use the video on the iphone to get right into the capping station with the flash on, you get a great video and it shows up the slightest bit of fluff or dried ink.
  • Reza Faezi
    27 June 2013 at 12:35
    Mmm, we were advised to change it every couple of years on our Mutoh VJ and we only just changed it a few months ago (after 5 years). We didnt purchase the Original Mutoh capping station 1st time either and we had trouble with it sealing properly. After a few weeks, it seemed to sort itself out (or a little ink built up where the seal was failing)
