Home Forums Printing Discussions General Printing Topics Advice on Laminators
  • Advice on Laminators
    Posted by Dale Briggs Harrison on 13 November 2012 at 19:03
    Hi Guys and Girls
    Been a long time since Ive been on here so hello again 😀
    We have recentley purchased a Vs540 & are now looking at purchasing a Laminator, we have been offered many models some with Heated roller upto 40 /60 degress & then others that go upto 120 !
    Not sure when the higher heat is needed as upto now we have always cold laminated (using a easymount 720 cold laminator) without too much trouble, but as we are to make a new investment I would like your input as to when it is neccessary to laminate with temperatures over 60 degrees ?
    Makes & Models ?
    Any help would be gratefully recieved ! (?)
    Dale
    David Hammond replied 12 years, 11 months ago 2 Members · 2 Replies
  • Fabrice Menard
    14 November 2012 at 13:24
    As far as I understood, the higher temperature laminators required hot laminates (only used for paper lamination/encapsulation?) although they also laminate cold.
    The laminators with lower temperature do require cold laminates only, the cold laminates are only heated a little bit, I guess it is for best adhesion but not sure, I own myself only cold laminators.
    So unless you want to laminate papers, a hot laminator is no use for you.
    Could someone confirm what I wrote?
    14 November 2012 at 16:27
    heated rollers apparently help reduce silvering.
    I do a certain job that involves loads of laminating, and most of the matt finished require running through a hot machine to remove silvering.
    The really hot ones are as said probably suited to encapsulation: Which does have it’s uses.
